Hi guys,
I just tried installing the evermax 120mm fan onto my xp-120 following the instructions I received in the box. However, the picture shows the fan clips (the bent part) going into the 4 corner holes of the fan. However, the evermax fan I have doesn't have those holes. I then proceeded to clip the clips onto the fan, no holes to hook into, but it feels tight nonetheless. I was wondering if anyone else had this setup and installed the fan this way as well. I'm just not sure if the fan will move or fall off during use.
Thanks
Andy
Thanks
Andy
