imported_Aelius
I received my XP-120 Heat Sink about 15 minutes ago from Sidewinder Computer Systems Inc.
I ordered it last Thursday the 5th using the only shipping method allowed for a Canadian order. Nice to see the super quick turnaround time.
I made this thread to note both good and bad points (yes there is one).
The kit includes the following:
HSF Body with 2 mounting clips X1
Blue Rubber vibration damper strips X2
120mm fan wire clips X2
Thermal paste in syringe X1
K9 Adapting RM X1
M3 0.5*15mm screws X2
First of all the heat sink is really light despite its massive appearance and let me just say it is massive. The pictures don't do it any justice until you hold it on your palm and realise that it is virtually larger than your hand.
You will be happy to know the kit includes instructions on how to install the XP-120 on both an Intel P4 as well as an AMD K8. It comes with a single CPU Adapting RM to allow installation for both types of CPUs. The CPU bracket appears to be made out of some sort of high quality composite ABS plastic. It isn't flimsy at all and I doubt its easy to break.
The construction of the XP-120 seems high quality as well. You can see some heat marks on the aluminum but that's normal from my experience.
My real concern is the base of the XP-120. Unlike some other heat sinks you can get a fair ammount of reflection if you put something next to it, which would confirm that they tried really hard to make the base smooth for a good contact.
Unfortunately my XP-120 came with a tiny machining scratch on one side of the base (thankfully not the middle). The rest of the base has clearly seen fine machining mark all over it. Much like any other heat sink.
I have no doubt in my mind that despite Thermalright's suggestion that we don't lap the heat sink it might be a very good idea to do just that.
Personally mine can't get any worse than it already is. Although I doubt that every XP-120 comes with a scratch on the base it doesn't make me very happy to know that I lucked out.
Having said that the scratch doesn't appear to be very deep and I'm confident that laping will remove it altogeather.
My next step is ordering a couple of laping kits to make sure the base will get perfect contact.
I can't provide pictures because I don't have a digital camera at this time. Priority goes to my new system. The toys come later.
Hopefully I can provide some #s later on once my system is up and running in the next 3-4 weeks (damn you MSI). I'll start a new thread for that.
I know this was somewhat limited but hopefully helpful to some of you.
K9 Adapting RM X1
