xigmatek s1283 - do i need anything extra to mount to a s775 system?
it comes with pushpins for mounting to 775 (same as Intel stock coolers), some people replace them with a bracket/screws, but it's not necessary...
on a related question, are the push pin systems such as this compatable with the brackets for the bracket/screws system? If I already have a bracket which came with the motherboard, can I use it with a push pin system?
Thanks,
~Lyuokdea
Thanks,
~Lyuokdea
I don't think that will work but you could likely make a trip to lowes and cobble something together. I would just spend the $7 and get the kit.
