XFX Radeon RX 6800 16GB $379
VirtualLarry
56,587
10,225
manly
13,443
4,161
Around Black Friday this was $370 and I thought it was a solid deal at that price point. It also qualified for a Zip payment promo (and maybe Affirm promo at another point), which was about a further 10% discount.
$400 is a tougher price point to recommend because of the GeForce RTX 4070 Super launch. Now $599 is in a different stratosphere IMHO, but it's also a lot more future proof. There is already some price pressure on AMD, and the newer RX 7700 XT is within spitting distance at $430. Just noticed the RX 7800 XT has dropped down to $500 for several models.
I'd recommend the RX 7800 XT if it can get down to $480ish; try to wait for another Zip or Affirm payment promo at Newegg whichever components you need to buy.
GodisanAtheist
8,437
9,845
OTOH most 8gb 4060 it's are at the $399 price point and the 16gb ones are roughly $460.
So if $399 is a stretch budget and parts above that price point are just not in the running, the 6800 will offer you the best raster performance out of its competitors.
DAPUNISHER
32,267
33,027
What's missing on the "core" models? Less display outputs?
I have the QICK model and the only difference I can find from this SWFT, is mine has snazzier front and backplates. Clocks and features look identical. And can confirm, the card is a heckin' chonker. Make certain it will fit in your case. I had to pull a HDD drive cage from my Phantek full tower to make it fit. Worked out long run since my Hellhound 7800XT is a big boy too. Amusingly, the QICK fits in a CoolerMaster nr200 easier.
You also need to edit the title to reflect the current $20 price drop.
The QICK 7700XT is $40 more with 4GB less. About the same performance too. Unless you really need the AV1 encoding not certain it's worth the extra money?
manly
13,443
4,161
New Zip payment promo means this is probably the cheapest net price it's ever been, and probably one of your last chances before Radeon RX 6000 series disappears from retail completely:
The only comparable deal was when a 7700 XT dropped to $353 briefly, but that was probably a price error. If you want to go higher end, the same Zip promo will apply to a newer, better card of your choice. There is a $6 finance charge built into Zip payments, so you're looking at about 15% off.
Otherwise, to get similar value, you'll have to get a used graphics card.
DAPUNISHER
32,267
33,027
They must still be making these. There isn't any other brand left NIB from Amazon or Newegg. Best card at the price point.
