XFX GeForce 9800 GT 512MB DDR3 256-bit 600 MHz PCI-E 2.0 SLI DirectX 10 Video Card - PVT98GYDLH
Price: $132.99 - $30 mir, exp. 11/30 = $102.99. Free ship. Tax in some states. With this 5% off coupon, price is $96.34.
The XFX GeForce® 9800 GT powers extreme HD gaming and entertainment, setting a standard far beyond expectations both in price and performance. Watch as we reveal things you've never experienced, pushing your gaming to limits you never knew existed.
Features
High-performance single-slot copper cooler
112 Processing Cores
NVIDIA unified architecture
Full Microsoft DirectX10 Shader Model 4.0 support
NVIDIA SLI®-Ready technology
NVIDIA HybridPower? technolody
NVIDIA PhysX?-Ready
NVIDIA CUDA? technology
True 128-bit floating point high dynamic-range (HDR) lighting with 16x full-screen anti-aliasing
PCI Express 2.0 support
NVIDIA PureVideo® HD Technology
Two dual-link HDCP Capable
OpenGL 2.1 support
Tech Specs
Specs
Chipset NVIDIA: GeForce 9800 GT
Bus Type: PCI-E 2.0
GPU Clock: 600 MHz
Shader clock: 1500 MHz
Memory Bus: 256-bit
Memory Type: DDR3
Memory Size: 512 MB
Memory Speed: 1.8 GHz
Thermal Solution: FANSINK
Minimum Power Supply Requirement: 400 Watt / 6-pin connector
Outputs
TV Out: HDTV
VGA: 0
DVI: 2
Dual-Link Support: DUAL
HDMI: NO
OTHER: SPDIF
Max Supported Resolution (DIGITAL): 2560 x 1600
Max Supported Resolution (ANALOG): 2048 x 1536
Features
GeForce Boost: NO
PhsyX: YES
HybridPower: NO
CUDA: YES
RoHS: YES
HDCP YES
NVIDIA-SLI READY: 2-Way
Low Profile Compatible: NO
