XfX 8800GT temperature and fan control
Rebel50
38
Just picked up an XFX 8800GT and installed the drivers and utils of the disk that came in the box.
After running the card for about 15 - 20 minutes, I decided to check the temperature by touching the plastic covering on the heatsink - it was almost too hot to keep my finger on it.
I also noticed that the fan on the card seemed to be running at a slow speed.
I checked the Vtune app that was installed with the drivers - the temp reading indicated 70 deg C - ouch!
There appears to be 2 options in Vtune for fan control - 1 as auto fan control and the other uses a set fan speed for 2D & 3D apps
I decided to use the latter and raise the 2D fan speed to 60% - resulting in te temp dropping to 58 dec C.
So is the temp of 70 deg C normal for these cards and is there an app that adjusts the fan speed in relation to the card temperature ?
Regards
Rebel50
38
Thanks mate - just what I was looking for.
Next time I wil remember to use the search funtion on the forum :)
