i just bought the above card from newegg the prevous weekend. mainly i have been playin DCfinal (battlefield mod) and CoD2. cod2 works like a charm and it gives me no problem. but dcfinal sometimes gives me problems.
the specs of the card are
http://www.newegg.com/Product/Product.asp?Item=N82E16814150120
it's on the stock hsf with 44c/52c (from nvmonitor). i just tested my CPU and RAM and found no problems with it. the drivers i use are nvidia nforceware 81.94.
with dcfinal, sometimes the display is broken and not continous. i play at 1024x768. this has happened to me quite a few times now. once the display starts to break, so does the sound. i think it could be the drivers but with cod2 running fine leaves me in confusion. restarting also doesn't solve this problem. (btw, the temp are from nvmonitor. if there a better s/w to check the temps and voltages of the cpu, gpu, chipset then please let me know.)
what could the issue be.
