so i'm trying to figure out what's going on with this xfx 7600gt. using win7 x64 and nv 295.73 (also tried 295.51). in any case, the fan is stuck at 100%. nvinspector and rivatuner don't do anything. i mean, i can change the setting, but nothing changes.
i searched on google and found others have the same problem with this particular xfx model, but they were mostly using winxp. makes a difference? anyway, i tried searching xfx support, but couldn't find anything on these old models. i was intending to see if they had released a newer bios which addresses this problem.
any ideas on how to fix it? or one else have this card and have the fan working normally? maybe i can snag the bios from you.
thx
thx
