Spec:
Asus P7P55D-E PRO (Latest Bios 1602)
XFX 6950 2gb Crossfire
i7 860 Intel
Antec Quadro 1000W
G.Skill F3-12800 9-9-9-24 2x2gb
1TB WD Black
Windows 7 64bits
CCC 11.1
I had issue with my crossfire for 3 days now. Low FPS in games & bench.
See: http://forums.anandtech.com/showthread.php?t=2141824 & http://forums.guru3d.com/showthread.php?t=338490
Someone pointed out a utility by AMD to check PCI-E Speed test. This test the CPU > GPU & GPU > CPU speed.
PCI-E Speed test Tool can be found on http://www.xtremesystems.org/forums/showthread.php?t=225823
Unless this tools ain't working for 6950 card. I'm the luckiest guy ever that got 2 defective XFX 6950 or this is a issue with this batch\6950 XFX\Asus board. (I had terrible speed on MSI as well so i dunno about that)
I ran my test with only 1 XFX 6950 (both of them give me the same result) and my old XFX 5970.
Please ppl using XFX 6950 post you're result with spec. Would also be great to get result from someone with the same spec as me.
Here the proof:
XFX 5870 test: You can see the GPU > CPU goes over 5,000 GB/sec
6950 test: Here it's under 520 MB/sec .. Something obviously really wrong.
I Sure hope this tools ain't fubar on 6950 card .. Cause im seriously fed up of testing.
i7 860 Intel
Antec Quadro 1000W
1TB WD Black
Windows 7 64bits
CCC 11.1
Here the proof:
