XFX 6600GT Temperature
Its Overclocked to 544/1090 (500/1000 Default)
Iddle its 54C and loaded from 63 to 70
Its that normal? If not what the hell happens. The card runs aweasome I have 66.93 drivers. You mentioned a driver remove tool please post the link, by the way what driver you recomend.
return merchandies authorization i think, you send it back to the manuyfacturer and get a new one if yours is defectivee
My XFX 6600GT also idles quite high (51C), but under load doesn't go past 65C. Why would it idle high, but have normal load temps?
Yes but the Memory Clock is 1200 on the test.
Other thing is that my xfx is not like that the fan with the drawing its all cromed. Maybe I am fu ked, or maybe thats better?
If anyone knows...
