Kwisatz Haderach
I just picked up this card today for an upgrade over my 8800GT. It works great, and is a pretty good upgrade. I just have one question. The fan pulses. The temp is showing idle at 43C. The fan will go from 0 to 50% fan speed for 1.5 seconds and then go back to 0, or at least less than what CCC can monitor. I have to use Riva Tuner just to see than the fan is changing speeds, but I can hear it.
When I run a game, the fan will run constantly as it should. Is it normal for the fan to run up and down like this at idle. It runs up for less than two seconds, and when it goes down in rpm, it stays for 3 or 4 seconds and then speeds up again. MY temps are pretty good, I idle at 43C and Max load at 68C.
Thanks
Thanks
