Powermoloch
Gah !
after I figured my 3650 HD died and installed the 4650 xfx replacement card a month ago. Then another problem pops op and it's fan started to stutter with grinding noises in the chassis. Is the fan failing?
My lil bro's PC is hp a6683w. I figured the vga has been positioned upright(vs upside down) could be a problem? I turned the case upside down to see if the fan could work...it works! Then again Why would I want my case upside down to begin with :/.
I checked the following:
- No dusts, almost dust free.
- PSU was adequate. 450 W
- Made sure the VGA fan gets the power (although it doesn't work off an on)
- Wires were well kept.
And my questions:
- Does a vga fan fail over time? (never OCed mild use)
- How's XFX service?
- Can the card be used even if there's a 120MM fan blowing on it?
- IF the service fails, what's the best replacement fan/HSF configuration would u guys recommend..dirt cheap of course nothing too special.
Cliff:
- Fan pooped 4650XFX , making stuttering/grinding noise.
- dust free, good psu, 1 yr of use
And my questions:
Cliff:
