grohl
Having a hard time figuring out what is 1) normal and what is 2) safe for GPU temps.
I started wondering since my new build freezes/shuts down after 15-20 minutes playing BF3 (2500+/8Gb/6950 @ stock, for now). It's a dual fan card.
When running OCCT 4.1 the program shuts down at 7-8 minutes when GPU temps reach 85C. Then I realized the fans do not spool up when stressed (my 4870 did). When I set the fans manually at 100% the test successfully runs for one hour but the GPU temps max at 89.5C.
Airflow to the case is pretty good. Three case fans. MB temps max at 37C and CPU is in the low 50s.
Wondering if there is something faulty with the heatsink or cooling of this new card? XFX says its ok for temps to be in 80s-90s, what do you guys think?
