So my 5970 was running fine, then about a month ago everything started running slower (namely BF4, but everything was affected). I checked CCC, and it stated that Crossfire was disabled. I checked GPUz etc, so I uninstalled and installed newest 14.4 drivers.
I got Xfire working again (though only under 13.9/14.4/14.6), but in 13.9, the PCIE frequency is x1/x1, and under 14.4/14.6, it's x4 (master) and x8 (slave).
Under Xfire everything has massive stuttering and frame drops Dota 2, a game that worked flawlessly under Xfire now chugs while using Xfire....but runs fine when I disable Xfire under specific application settings in CCC. Other games like BF4 run horribly either way because one GPU isn't enough, and it lags while using Xfire.
The only problem I noticed is that GPUz states that my lanes are PCIe_16 2.0 X4 for first GPU and X8 for 2nd GPU under 14.4. I don't know what my GPUz was before the problems started showing up, but I'm wondering if the X4 for first and X8 for the second GPU is bottlenecking my 5970?
Here's my GPUz screenshots and 3dmark 11 results:
GPU1:http://gpuz.techpowerup.com/14/07/02/d8d.png
GPU2: http://gpuz.techpowerup.com/14/07/02/fqv.png
3dmark11 results: http://www.3dmark.com/3dm11/8457708
Also I got 3350 points with Furmark's 1080p benchmark.
BTW I tried removing the GPU and reinserting it into the slot (2.0 x16 slot), and also tried putting it into another PCIe slot. The results were still x4/x8 in both cases. ALso checked my mobo settings to see if anything was up...but couldn't find anything (mobo is ASUS p8z68-v-pro)
Specs:
P8z68-v-pro
8GB RAM
Diamond 5970 (reference, they didn't modify anything)
I don't know anyone with a big enough case/PSU to fit a 5970, so unfortuntly haven't been able to try it in a different computer
Specs:
P8z68-v-pro
8GB RAM
