google showed
this
While all Intel processors since the Pentium Pro have internal die temperature sensor diodes, new circuitry has been added in the Pentium 4 and Pentium 4 Xeon processors permiting automatic control of thermal dissipation. When the temperature sensed by a second diode situated in the hottest region of the die reaches a factory defined threshold, the internal clock is automatically stopped until the temperature drops by about one degree celsius. On-off reaction times may be as short as a few microseconds, so that despite high rates of temperature buildup of 30-50 degrees C/sec, the regulator keeps dissipations at or below the Thermal Design Point.
Evidentally, if the Thermal Monitor system is enabled, the most power the CPU can be made to dissipate will be approximately the Thermal Design Power, and Intel operational specifications for the Pentium 4 require that the Thermal Monitor throttling be enabled, either in BIOS or via software driver. However, like the Athlon XP, the CPU can be operated at higher dissipations if the Thermal Monitor is left disabled.
When operated at the same clock rate and core voltage, AMD processors for a particular stepping have similar thermal ratings, but Pentium 4 processors may have very different ratings even though they have the same stepping. As an example, data for Pentium 4 stepping B0 are plotted below:
seems that they do...and being the flagship,it wouldn't make a lot of sense for them not to.
mike
