Hello
Well i have a problem i hope someone can help me with. I have been running my old Core I7 920 at 3.6Ghz for over a year now and i started to looking around for a replacement CPU for my system. Well a 6 core was the only choice but i don't have the money to buy a 970 or 980x.
Now i found this and it should work fine with x58 boards except some motherboards. Mine booted fine at stock 2.1Ghz. But as fast as im trying to raise the BCLK it wont boot! I have tried changing the V core to 1.250v but still nothing, Ram voltage still nothing. I was hopingi would be able to overclock this beauty to at least 3.2Ghz but no
, Wont go one Ghz above stock.
Now i turning to suspect the memory modules i have. The post screen shows 1333 mhz at stock speed but i have Corsair 1600mhz memory modules. It hangs at the code C1 when trying to raise anything that has to overclocking to do. Help plz
How come i can clock my old 920 but not this one. Now i cant remember the settings for that CPU as i had to reset Cmos which was a big failure as i didn't save the settings
Feels like it must be a RAM related issue?
System spec
6core Intel XEON-L5639 socket 1366
Gigabyte Ga EX58-UD5
6X 2GB corsair tr3x6g1600c9
Gigabyte GTX 580
Intel 160GB SSD gen2
*EDIT*
Just wanted to share my experience a bit
. Link below where I found the problem!
http://forums.anandtech.com/showpost.php?p=35702057&postcount=38
//TH
System spec
Gigabyte GTX 580
*EDIT*
//TH
