Alessandro
I recently set up a system with a Xeon E3-1230-V3. I am using the stock heatsink but wiped off the default paste (using rubbing alcohol and coffee filter) and added Arctic MX-4. For temperature, at idle it runs in mid-30s, and during regular windows usage, tops out at low 50s (all temps in C of course).
The problem is, when I run Prime95, it quickly sends temps high (I had read that tcase for this processor is in the low 70s ... I turn the system off when it gets past 75C when running Prime95 as I don't want to do damage). My case ventilation isn't great, but I would think the temperature wouldn't just rocket so high so quickly (within 5-6 minutes on blend, within 1 minute on Small FFTs test, always torture testing 8 threads). Is this to be expected with the stock heatsink (given it is not overclocked ... I would think the stock heatsink could handle things)?
