ShadowBlade
so i got a used xbox dance pad and put a usb end on it, works fine...for a while
everything works just as expected for about 2 mins and then i have to uplug and plug it back in for it to work, im guessing its wired correctly since it works fine for a while
using stepmania (obviously) and xbcd drivers, the pad worked perfectly with an xbox before i did anything to it
