So I purchased a powered hub and an extension cable (30 feet) to go from my rack to a midpoint in the room so we can hook up RB drums and a mic.
Well it doesn't work with the hub or the extension in the mix at all.
If I use a couple of plain generic extensions (about 6 foot each) they work fine with the drums. I only have 2 extensions in the house but I can put both on the end of the drums or the mic and they work fine.
Anyone have a suggestion on a hub and an extension that can go the distance I need? Is there a powered USB extension around?
TIA
Greg
TIA
Greg
