Question X870E AORUS MASTER bluetooth issue
boed
Hello,
I just got a X870E AORUS MASTER rev 1.1 with the current bios. I downloaded the latest drivers for everything including the wifi and BT. I've rebooted. Bluetooth shows in the taskbar but can't find anything -I know these devices BT work and they don't need to be reset they can connect to multiple devices such as my BT headset, keyboard and mouse.
BT is set for the pc is discoverable
I look in device manager and it says under other devices - Bluetooth peripheral device.
I uninstalled all my BT devices - including under hidden and then reboot
It comes up in device manager
BT Device rfcom Protoco tdi
Generic BT Adapter
MS BT Enumerator
MS BT LE Enumerator
But under other devices
I reinstall the driver, reboot - same
I see it is using a Qualcom driver but I on the Gigabyte support page. Supposedly there is a newer QC driver but I can't find any place to download.
I've run the troublehooter it says it finds the BT radio.
not sure what to do.
PS my wifi works fine.
PPS - I put in a usb bt adapter it discovers them fine - while I could stick with this I'd love to get the one that came with my motherboard working - not exactly sure what qualcom BT adapter it is e.g. atheros, 7800... or where to get the latest driver for it.
Qualcomm wifi 7 sounds like a QCNCM825 or 865, fastconnect 7800 based.
You can grab the cabinet file for the latest bt and wifi drivers here. Unpack them and point device managers "update driver" for each device to the folder where you unpacked the cab.
3.1.0.1407 is definitely newer than Gigabytes listed 3.1.0.1262
