Hi, I'm trying to hook up my HDTV monitor to my new X850XT so I can watch HDTV content with my ATI HDTV Wonder card. However, i'm running into difficulties when using the 9-pin HDTV Component out cable included with the X850.
I booted the computer with ONLY the HDTV monitor attached, using the 9-pin cable. I was surprised to see the BIOS POST tests already being displayed by the TV. I was under the assumption, according to ATI's website, that the component video won't be displayed until Windows is initialized. Anyways, while I could see the computer's normal bootup output, the colors were way off (ie, Windows logo), and it was considerably fuzzy. Everything was light bluish, and possessed no other colors. It's as if it were black and white, with blue in there as well. (My first thought was that the Component cable colors were mixed up, so I switched those around. The only difference that made was changing the bluish color to a magenta color).
When I got into Windows, the display was set to Default Monitor, and when I went into the ATI CCC, the HDTV monitor showed up as a general TV device (and had none of the same options my normal VGA computer monitor does. I was expecting to see the HDTV Support option, which is usually available, but it wasn't there.)
I'm Googling this like crazy, but I just wanted to throw this in here in case someone has had similiar experiences hooking their X800 series cards up to a HDTV. Anyways, thanks for the help!
P.S. I'm using regular A/V RCA cables for component input. I know, I know, everyone says you should use the "real" YPbPr cables, but i've had no problems in the past using the regular Red/White/Yellow ones. I've successfully been able to watch 1080i content, from an HDTV OTA receiver, on the same HDTV monitor i'm trying to use now, using the same cables i'm using now. So I don't think the cables are the problem.
