Aug 23, 2005
200
My x800 pro died, i couldnt figure why , so l took of the heat sink and found i have somehow cracked the corner of the gpu, OOOOOOPPPPPPPSSSS !
Now it wont draw a 3d picture ! hahahaha.....
Still runs in 2d mode at desktop though ! yay ! not !
Anyone want an x800pro ?
Its going cheap cheap !
I susspect i cracked it taking this monstrosity of a heat sink off/on, its not factory original but rather this alloy that wraps right around the card, well its name i cant remember and it was a fiddly crappy thing , only took 3 degrees of the overall temp anyways and l was gunna boot it off ! ooopps !
So now theres an ATI 9550 in the old girl aaarrrgghhh , sheeeesh , poor pc !
It wont load HL2 , hahahahaha , luky its on the 2600+.................
kruull
110
thesurge!!!!:
Just wondering - what manufacturer is your GTO? What are u cooling it with?? Temps?
kruull
110
Originally posted by: thesurge
Using stock cooling with a Sapphire x800GTO (fb). Temps get a little steamy, 45idle/65load.
pic
You must have got a pretty decent chip - my max with the same card is 603.8MHz for the core: anything above = artifacts!
