X800 Pro vs X800 XL vs 6600 GT
MrFire8808
Hi..
Im curious which of theese would be the best to go with? Im on a bit of a budget, but is it worth it to just move up from 6600 GT and get an X800?
And if it is, X800 Pro or XL?
Thanks!
Edit: I forgot to add that Im getting a A8N-E nForce 4 mother board and a AMD Athlon 3200+...
What resolution and quality settings do you play on?
If 1280x1024 with little to no AA or AF, then 6600GT is, by far, the best bang for the buck.
Since you're going PCI-Express, you might as well go X800XL. X800XL is equal to 6800GT in performance and it's only about $260-280 anywhere. If you're playing @ 1280x1024, you might appreciate the X800XL as you can jack up AA and AF.
Definately the XL.
it gets a little annoying when people keep using the SM 3.0 argument as the sole basis of making an endorsement for an nvidia card. I'm no ATI fanboy or nothing but its just bad. The FX5200 is DX9 compliant, does that mean all these current games like it more? Please once and for all understand that its just a feature set, not a quantum leap in performance.
Search on his posts, he's like a broken record. :roll:
that i am! I will fully accept all major hate flame/making fun of me IF sm3.0 doesnt turn out to be great or if the 6600gt sucks at all future games on lowest settings.
BUT, don't bring in the 5xxx series into this...that is TOTALLY different.
If SM3.0 ends up being great with the 6xxx cards, i'll be happy for being the only broken record here!
Originally posted by: Sc4freak
X800XL is the fastest of the lot.
Obviously. Does that mean it's best to get? The X850XT is faster than the X800XL, so should he get that for $500? :roll:
If you're on a 17" LCD, then get the 6600GT. R520 and G70 are going to dwarf the X800XL. Nobody will want to pay you $300 for your X800XL used when they can fork over another $100 and get one of these next gen cards that has who-knows-how-much better performance but it could be double. A 6600GT, like a 9800 Pro, will still be desireable to the budget gamer sector or to people looking to pick up a second one for SLI.
X800XL is a faster card, but at almost double the price is isn't double the performance at 1280x1024....not even close. There's no game coming out in the next 12 months, from what I've heard, that sounds like it will require more than a 6600GT....including Unreal3, AoEIII, or BF2. If it plays those games well, then it should be able to last you until the next gen refresh which should include DX10 compliant cards and you'll be looking at a REAL long term upgrade solution at that point.
If you like AA, get the XL. If you can do without it, get the GT. Benchmarks show them to be roughly equal price/performance buys at ~$300 and ~$180, respectively. The X800XL can certainly be double the performance due to its doubled memory bandwidth and memory size, and its almost-doubled fillrate. The key is AA, which will often put you over 128MB at 12x10. In these situations, the GT's framerates will stumble, and the XL's won't. But you can always either turn down the texture quality or simply omit AA to keep the GT running at top speed.
If you want the SM3 effects in the three games that currently tout them, then I guess you have only one choice. Just check out the framerates with those SM3 effects before you buy: Far Cry, Riddick, SC:CT. Having the option is better than not, and future games may not show as much of a performance hit, but--aside from SC:CT's small performance and supposedly noticable IQ gain--SM3 currently doesn't look like a must-have feature for the 6600GT.
Since X800XL is often 2x faster and is equal to 6800GT but costs $290 vs. $180 for 6600GT, I think it's a better value. You are getting double the performance in high resolutions for 1.5 times the price. If you dont use AA/AF settings and dont play at high resolutions, go with 6600GT.
Review 1
Review 2 - most extensive
Get the XL i had the chance to use my buddies in my rig while he was waiting for his PCIe and i liked it better than My 6600. I already have the 66 and it's a great card. I sold my X800 PRO when i moved from AGP to PCIe. I wish i would have bought the XL when CompUSA was selling it for 250. No matter what card you pick you'll be happy. I'm a big Counter Strike Source player and i play on 1024x768 4xAA every thing on high and it dose just fine. I have yet to see any lag in video, maybe ping wise but not video.
6600gt is a mainstream card: MAINSTREAM!!
the X700pro/9800pro are comparable to it. the purpose of this thread is completely dumb with some of the ppl who play along in it too.
you could've told the guy already to stop insulting all our intelligence and at least compare apples to apples.
price segment (msrp according to ATi & nVidia) matchups:
x700 / x600xt - 6600
x700pro / 9800pro - 6600gt
6800 - x800
6800GT - X800pro (and after a 8month refresh the cheaper X800XL on pci-e, the X800XL agp = still $350)
6800U - X800XT (later X850 series which are newer & cheaper/performance)
so... What are we comparing again?
the vice versa of a 6800GT and a x700pro?
that's like comparing a ferrari with a tricycle.. or did you really find a X800XL for $149?
according to www.pricewatch.com the cheapest 6600gt's are at $149 the cheapest x800pro's at $273 and the cheapest x800XL at $273.
that's why this thread's purpose seems completely retarded, try making a valid comparison next time.
6800 - x800
Well put, thank you.
a) it's not double the price
b) it has double memory size, double memory bus, double the pipelines
c) in fact it has almost double the performance of the 6600GT
d) performance doesn't scale linearly to the price, especially not at the high end -
for example 6800Ultra costs 25% more than 6800GT but is only 10% faster.
Overall, given the price difference of less then $125, I personally would go for the X800XL since it offers a completely different performance level. But of course for peole who don't want to spend more than $200 on a video card, the 6600GT is by far the best value in this range, and offers very good performance which lets you enjoy most game with reasonably high details and resolution.
