X800 & 6800 Filtering Quality: NV Wins... I think?
StanTheMan
510
sorry to interupt mate, thi may be quite off topic. nvidia has just updated the latest driver to 71.84. but then i can't find "refresh rate overide" option in nvidia's newest driver. anybody know where it is?
CHfan4ever
3,290
Originally posted by: THUGSROOK
for me its quite the opposite....
i get a higher framerate using HQ off off off then i do with Q off off off.
Q on on on is the fastest tho.
maybe its just a CSS thing?
Not at all.I have tired World of Warcraft and i get an amazing performance boost.Tonight i will post some screenshot about the difference.( just dont have time atm, gotta go work)
In an area.I use MAX detal, everything mid aniso( 2xq AA and 4xaf on card) quality....and get like 65fps.In order to achive the same fps on high quality, i have to turn the terrain distance to 1/3!!!!
In credible...what a find...my system now stay with quality setting lol
VIAN
6,575
I have now updated the original post to show people who needed exact same position shots. There are new ones, that's as close as I'm gonna go.
Jun 14, 2003
10,442
Originally posted by: VIAN
oh and i take your screen shots with a grain of salt, since you are in different position in all of them, if u wanna do a comparison you need to be in the exact same posiition to make it count
The first set are in the exact same position. Although the second set aren't I assure you that the same thing is still there. You're just in denial. Anyway, you can go test it for yourself. Got COD. Go to the rocket area with Quality enabled and Anisotropic Filtering at 8x and go see for yourself. And then change it to High Quality and notice the clean beautiful surface that you paid much money for. If you read the above carefully it only appears with defined pattern so, it'd be really hard to find it some games that don't have textures like those, but many games also do have textures like those, maybe not everywhere, but they do.
You will certainly see more contrast with an ATi part- their texture filtering accuracy is so low it gives the appearance of increased detail although it is aliasing artifacts more then anything. I've been running my R9800Pro for over a year now and ATi's texture filtering is extremely poor at best. Not saying that the current nV parts are a lot better, they have been on a downward trend since the last part that actually did real anisotropic filtering(the NV2x core parts).
I can attest to that. But I still believe that ATI has better default IQ than. But if you set Nvidia to High Quality, it will have less, unnoticeable, textures shimmering and better overall image quality, if Trilinear is working.
hey, where's "refresh rate overide" option in nvidia's newest driver (71.84)?
It's missing.
i have the new valance studio drivers based on the 71.84's so i may not see what you see. the IQ on these is simply amazing
THUGSROOK
11,847
Interesting, how much difference was there? Was it withing a reasonable margin of error?
yes, but Q off off off is consistantly slower then HQ off off off.
VIAN
6,575
Flipping through those first shots looks like High Quality is a bit more detailed in the farther textures than Quality.
I see no difference between the middle shots.
The last shots looks like Quality is more detailed than High Quality, you sure you labeled them right.
Udated: Quality introduces Aliasing making the image look more defined in the screenshots, but in reality, it's just artifacts.
CHfan4ever
3,290
I dont have an ATI card.What can be done to do similar thing so i can help my friend who have an ati card?
VIAN
6,575
Just default performance/quality settings in the drivers except Anisotropic Filtering to 8x, vsync always off.
In COD, HL2 turn all settings to highest, but leave resolution at 1280x1024(not too big, not too small).
FarCry was set at High. Don't set Anisotropic Filtering in-game, do it in the control panel.
Use FRAPS to take pictures with similar positions in my pictures above.
In COD, the level is Rocket. Go underground and you will see the area.
HL2, first listed Deathmatch level.
FarCry, just the beginning before the phone.
Thanks.
housecat
Banned
Oct 20, 2004
1,426
Originally posted by: Insomniak
This thread is LOLable in the extreme.
Word.
It's missing.
This thread is retarded.. but if it gets you off for some reason then go for it.
The IQ is not that different, unless you are basically photochopping and zooming in or being a real geek here. And performance from NV HQ to Performance modes is not much performance either.
Thought I'd let you know, since you guys are "SO" knowledgable, that you need coolbits 2.0 to enable the refresh rate override in "nvidias newest driver 71.84".
Check guru3d for it or do it manually.
The instructions are on nzone.com
You really arent l33t enough to be investigating NV/ATI IQ like some expert. Esp if you dont know where the refresh rate override went.. sorry.
I dont see how someone who cant figure something like that out (I know alot of ppl "lost it" with you) but its noobish. Seriously.
Even with the best tools sometimes there still needs to be a good mechanic. :eek:
And hence, no one is going to take this seriously but you.
But rock on it it gets you off. :thumbsup:
Anything else I can help you experts with? :D
Jeff7181
18,368
11
VIAN... not to be picky, but your new screenshots still aren't taken in the exact same spot... save the game at a point and don't touch the mouse at all so you get the EXACT same view. Otherwise it makes it pretty much impossible to compare textures off in the distance and quality of AF and trilinear or bilinear filtering.
Jun 14, 2003
10,442
*UPDATED 3/6/05
This thread is to prove that ATI has better default IQ than Nvidia (although that's not happening right now with no ATI pics) resulting in unfair benchmarking with Anisotropic Filtering enabled. And if that's not good for ya, it's also a challenge to this.
Nvidia states the difference between Quality and High Quality in this 10MB pdf:
Quality is the default setting that results in optimal image quality for your applications
High Quality results in the best image quality for your applications. This setting is not necessary for average users who run game applications. It is designed for more advanced users to generate images that do not take advantage of the programming capability of the texture filtering hardware.
Accompanied by a graph that looks like this.
There is and there isn't a difference between those settings, and any difference will be much more noticeable when you are in motion. If you don't enable Anisotropic Filtering, you will see no difference. Although there might be some subtle differences in certain situations like what I've seen in Call of Duty in the Ship level in mutlitplayer, differences like these are hard to spot. In this level you will notice it from a distance with the shadow of the railing of the ship.
If you turn on Anisotropic Filtering however, you will be able to see it on only certain types of textures. Sometimes you won't be able to see it at all, sometimes you'll be able to see it a bit in motion, and sometimes it will stick out like a black eye. Take COD for instance. The textures on the wall are nice, but never as defined as when there is are patterns on the floor. With Quality enabled you will notice artifacts that look like a crap load of texture aliasing a.k.a. texture shimmering with those patterns. It'll be visible in the pictures below(only on the patterned part). I'm pretty sure ATI doesn't have this problem as I never noticed it playin COD before. Also noticeable on the floorboards on the ship level. Painfully noticeable. If you follow the floorboards, you don't see anything, but as soon as you look at them diagnally or horizontally, then you have a serious problem.
Even at High Quality, there is just something weird about those textures that I noticed coming from an ATI card. For starters, not always does HQ do Trilinear - You may have to force it.
Being that Quality is default, benchmark numbers reflect this loss in Image Quality when they bench with Anisotropic Filtering, which is unfair to the competition that uses optimizations with NO Image Quality loss.
In the High Quality picture above, you will see that near the wall, there is a bilinear transition there. Trilinear is set however in the game.
Again in the High Quality pictures you are able to see some bilinear transitions, one is a bit farther than the lower, farther corner of the door.
If you are one of those dudes that was complaining about the second set not being in the same position. Here you go:
Although, these are using the 71.84 BETA drivers. There was an addition feature in 71.84 named Negative LOD BIAS, this was changed from default to Clamp.
If anyone can oppose that ATI has better default driver image quality with 8x Anisotropic Filtering enabled in an ATI pic, that would be great since I don't have an ATI card. But I'm looking into buying a cheap 9600 to prove this, but I don't know how long that will take.
SPECS
Athlon XP 2700
1GB Corsair Value Select PC2700
A7N8X-X
eVGA 6600GT - Forceware 66.93
Other than changing Image Settings in the drivers, Vsync was off and Anisotropic Filtering was set to 8x. Everything else left at default.
For Optimal Image Quality using drivers 71.84 without Anisotropic Filtering leave drivers at default settings. If you want Anisotropic Filtering, change the following:
Image Settings: High Quality
Force Mipmaps: Trilinear
Negative LOD BIAS: Clamp
PICS IN OTHER GAMES
HL2Q.JPG VS HL2HQ.JPG - Highest Settings, no Vsync
FarCryQ.JPG VS FarCryHQ.JPG - High Settings, AF set in driver, no Vsync
thats better, i think HQ just to say has the edge there, but its not something id notice playing. what does the Negative LOD do? does it help the filtering problems your documenting?
BenSkywalker
67
I didn't see any such thing in your link.
You can see it in every 3D PC game outside of Tron2.0 that I can think of. I posted the link in response as I figured you would try and deny their were any issues(as we have gone over this before) and I figured people who wanted the truth may be interested.
kylebisme
9,396
I'm not denying that Nvidia hardware uses more bits filitering, that is a simle fact. However, people who want to know the truth obviously want to see evidence of how that fact releates to the image quality in real world gaming situations. If it can be seen in "every 3D PC game outside of Tron2.0" then clearly it shouldn't be hard for you to provide screenshot or video evidice of your claims. Otherwise, claims of "filtering tricks" when even the article points out that ATI's implementation matchs Direct3D's reference rasterizer will only appeal to people looking for a reason to dog on ATI.
VIAN
6,575
Again this ATI filtering thing you will probably not notice, especially if you just play a game. But if take time from your FPS and look at the graphics and the beauty you will see it. But you will also see Nvidia's, although Nvidia's is cleaner. I don't think you'll be able to spot the difference in a screenshot.
I used to see the ATI filtering thing in COD in the grassy hills next to this town, can't think of the name at the moment.
Simple stuff like that you will probably never notice, but the crap I'm bringing up is very noticeable that it pulled my away from my FPS.
Anandtech will come out with and IQ article soon, bout the time of the launch, of the new cards and we will see what happens.
VIAN
6,575
housecat:
If it was simple enough that you had to zoom in to see it or something unnoticeable like that I wouldn't have bothered to put it up. If I was that picky, I'd be complaining about ATI's worse filtering where you could see a bit worse texture aliasing than Nvidia's High Quality.
This is not crappy stuff like that and for those that don't like aliasing and usa AA all the time, this isn't crappy stuff.
"Sometimes you won't be able to see it at all, sometimes you'll be able to see it a bit in motion, and sometimes it will stick out like a black eye." From first post.
You just haven't seen it. Maybe if I was able to host videos.
And I don't appreciate you being so condescending.
As far as the refresh rate override. 66.93 had them without coolbits, 71.84 didn't. I just downloaded refresh force. Easy. Done. Anyway, thanks for the coolbits tip.
No it's not and I made sure that you would be able to see the artifacts at any angle, distance whatever. I showed you in the COD screen shot the same places and it held true, so now I still try to go to the same place, but not as worried if I screw up. I could be playing Splinter Cell: Pandora Tomorrow right now, I don't need to be wasting my time.
But I think that it is important for Websites to start testing at High Quality instead of Quality. Because I'm pissed for buying a card based on a bunch of bechmarks compared to other cards with higher IQ. The card I bought should have had less fps to get the same IQ, but it didn't.
Nvidia drivers sux... That's why I use XG, the IQ is much better.
If it was about me, then I would, but other people are being duped in my opinion with these benchmarks.
Trust me, it only looks harmess on the picture. If you hate aliasing, you will hate it. In fact, even when you can't tell the difference within a picture, in real life when moving it will still contribute to more aliasing vs High Quality. Negative LOD helps sharpen textures without Anisotropic Filtering. If you enabled Anisotropic Filtering Negative LOD turns off automatically because it looks bad. I haven't seen it, but It's good that it's automatically controlled.
well id chose the quality if i was deciding from them pics, i just cant tell the difference and id rather have the higher FPS
Are you sure you are viewing the picture in it's original size?
kylebisme
9,396
I think you are reffering to ATI's crappy "quality" AF control panel setting only using triliniar for the first mip-map and biliniar for the rest. That is a completely seprate issue form the number of bits used for filitering which Ben brought up.
VIAN
6,575
No, I'm not referring to that. I think they don't do that anymore BTW.
He is saying that ATI has more aliasing in their textures.
McArra
3,295
Originally posted by: Robor
Originally posted by: otispunkmeyer
yes they are, im loving these XG 71.84s
What are the advantages?
They are tweaked for IQ without performance lost. Pretty good, try XG 71.84, you won't regret.
