Originally posted by: lyssword
quote:
Originally posted by: beserker15
I doubt the ram will really limit it as the x700pro would be quite a bit slower. The x700pro with it's 128bit bus even loses to the 9800pro sometime. The x800 should easily beat it.
I thought x700pro was basically a rebadged 9800pro? that being said, x800 should be slightly faster in most applications
The X700 PRO is a different arquitecture from the 9800 PRO, it is based on the X800 which is an enhanced version of the 9800XT. Look here the differences:
Card Codename Core RAM Speed Pipes Vert Bus PS Fillrate
9800PRO R350 380 680 8 4 256 2.0 3.04
X700PRO RV410 425 860 8 6 128 2.0b 3.4
X800 R430 400 700 12 6 256 2.0b 4.8
So, the X800 should be at least 20% or more faster than the X700 PRO cause has a higher pixel fillrate but the X700 PRO has a higher vertex rate. And the X700 PRO should be a bit more faster than the 9800 PRO, even though the latter one has a 256 Bit Bus, but the X700 PRO has a more mature arquitecture and a faster core and RAM speed, slightly higher pixel fillrate and double the vertex shader power. Sorry for the scrambled table, but I tried thousands of times to align it, anyways
