X79 Blue Screen Registry Fix Won't Stick
bradly1101
4,689
294
www.bradlygsmith.org
I made a post a while ago about IRQ_NOT_LESS_OR_EQUAL blue screens I was getting on a pretty rare basis. In running Driver Verifier I drilled down on the specific error by Googling and found an answer that worked. "If there is a Network Interface listed with no values in this key (HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\services\Tcpip\Parameters\Interfaces) just delete it."
That worked! The Driver Verifier error no longer came up, and I went months without an IRQ_NOT_LESS_OR_EQUAL blue screen (or any BSOD's).
The problem is that the registry entry keeps coming back and results in a BSOD.
Any thoughts?
Ketchup
14,559
248
Does it save to a dump file? If so, have you looked at it with a program like Whocrashed?
bradly1101
4,689
294
What does whocrashed say about the error?
On Sat 12/10/2016 7:25:45 PM GMT your computer crashed
crash dump file: C:\Windows\Minidump\121016-24492-01.dmp
This was probably caused by the following module: ntoskrnl.exe (nt+0x70400)
Bugcheck code: 0x9F (0x3, 0xFFFFFA800FBFA060, 0xFFFFF80000B9A3D8, 0xFFFFFA801C7F4010)
Error: DRIVER_POWER_STATE_FAILURE
file path: C:\Windows\system32\ntoskrnl.exe
product: Microsoft® Windows® Operating System
company: Microsoft Corporation
description: NT Kernel & System
Bug check description: This bug check indicates that the driver is in an inconsistent or invalid power state.
This appears to be a typical software driver bug and is not likely to be caused by a hardware problem.
The crash took place in the Windows kernel. Possibly this problem is caused by another driver that cannot be identified at this time.
Ketchup
14,559
248
Figures. But it's free. Sometimes they do have helpful tips. What OS?
Ketchup
14,559
248
You know, a virus will do something like that. What AV are you running?
Ketchup
14,559
248
I guess my next question is, how do you know the registry entry causes the blue screen? It may been a needed field on your install, and Windows restores it from the backup registry on the next reboot.
Glad to know you are virus free in any event. The virus I was referring to is about 2 years old, so MSE would have caught it if it was there.
bradly1101
4,689
294
The troubleshooting included using Driver Verifier since the BSOD indicated a driver problem. The error led me to this fix:
https://support.microsoft.com/en-us/kb/2550576
"c. Find the following registry key, and if the Data value is empty, remove the registry key.
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\services\Tcpip\Parameters\Interfaces\<your-adapter-interface>"
I checked and it does come back with every reboot. I originally posted this as a possible power problem here. There's a strange symptom when the PC is running fine the CD drive will cycle like it just received power. So despite MS's recommendation, I think that key is supposed to stay there, and I'm beginning to suspect the CD drive. It's a cheap Sony unit left over from another build.
Ketchup
14,559
248
But according to that, simply turning off driver verifier would fix your problem.
bradly1101
4,689
294
Driver Verifier is something you do turn off. I only get the Driver Verifier error when running Verifier, and that led me to this fix. If I delete the empty interface in the Registry, then run Verifier, it makes it past that error. I'm not sure why since it requires a reboot in between, so the registry entry must be back, but it works. If I get a blue screen (once in a few months) then delete this, I don't see the error or BSOD's in a long time. But I do get that strange CD power cycling.
