Jacky60
I want to go Sandybridge E 3930K with a view to upgrading to Ivybridge E if that's a viable upgrade path. I also want 4.6-5.0Ghz with something like a Corsair H100/Noctua NH14. Will an X79 mobo support Ivybridge E and will I be able to reach 4.8/5.0 using those coolers? I know its luck of the draw so I'm going to buy from a non specialist site (i.e. one where the staff haven't pre-screened all the cpu's to keep or sell the best overclockers in custom build machines for clients). Thinking of Asrock Fatality X79 or Rampage IV or GB X79 UD3-will the UD3 cut it (I may well go tri SLI/ trifire so want 3 PCIe x16 if possible?
An help/opinions/advice appreciated.
