x6800 CPU Speed Problem
donp2112
Brand new machine with a Core 2 x6800 2.93Ghz. nForce 680i mainboard. When I look up the speed it is showing 1.87Ghz (Sandra). I'm a noob so I don't know where to begin.
Thanks in advance...
From Sandra:
< Processor >
Model: 1x Intel(R) Core(TM)2 CPU X6800 @ 2.93GHz
Speed: 1.87GHz
Performance Rating: PR6348 (estimated)
Cores per Processor: 2 Unit(s)
Threads per Core: 1 Unit(s)
Type: Dual-Core
Internal Data Cache: 2x 32kB Synchronous, Write-Thru, 8-way set, 64 byte line size
L2 On-board Cache: 4MB ECC Synchronous, ATC, 16-way set, 64 byte line size, 2 threads sharing
< Mainboard >
Bus(es): ISA PCI PCIe USB FireWire/1394
MP Support: 2 Processor(s)
MP APIC: No
System BIOS: Phoenix Technologies, LTD 255.255
System: EVGA 122-CK-NF68
Mainboard: EVGA 122-CK-NF68
Total Memory: 2GB
< Chipset 1 >
Model: Nvidia Corp C55 Host Bridge
Front Side Bus Speed: 4x 267MHz (1068MHz data rate)
The-Noid
3,117
4
you computer has C1E enabled, so as your computer is not doing anything it puts the cpu multiplier to 6x to save energy.
donp2112
Great info, thanks. But the machine got clobbered in the CPU tests on 3DMARK06, does that make sense?
CurseTheSky
5,401
The processor's multiplier might just be set to a low value. Try manually setting the multiplier and disabling all speed-limiting features.
