X600XT problem
jlswier1988
119
I bought a x600XT 128mb video card for pci-express and im getting about 100fps constant in most maps on cs:source but the problem is this. When im running any directx 9 game it continues to get artifacts after a little bit of playing. I played flatout which is a racing game whice uses DX9 and i get it there same with source artifacts after less then 30 minutes of playing and i believe its a cooling issue but it could be defective or whatever i would like some either options of better cooling or tips of what i should do.
Right now my setup is
MicroATX MSI Motherboard RS480m2-IL
Aspire X-QPACK Microatx Case
Pc3200 gig of OCZ HP ram
939 64 3000+
I have 1 120mm fan blowing into the case should i reverse it for better cooling? cause thats the only fan that can be put in the case caues its so compact.
