X5470(mod) and P5QL PRO need suggestion for psu.
meganin
hello friends
i am gonna have xeon 5470 cpu soon,the mobo i use is asus refurbished p5ql pro (1 year now),graphic card i have now is nvidea zotac 730 ddr5 1gb,ram 3X1gb ddr2. sometimes burn dvds..
my usages are mostly hd videos streaming or downloading,playing counter strike offline,browsing with more than 7-10 pages at a time..
i want suggestion from you guys which psu i should buy for my particulars,for now i am using a very bad local psu just 450watts not a good one i am sure of that,but when i am going to use X5470,i really want to have a good psu but a cheap one ofcourse 🙂
thanks for reading and hope i would learn somthing good here,thanks
the one whiich i have now is local made,dont know its name,a computer guy gave it to me few months back when i wasnt home,but the values are just 15a in 12v rail,34 a in 5v rail..and when i did psu calcultion its showing recommended is 600 to 700 watts... i am not sure i can buy it any sooner,they are expensive,so is this 450 corsair is really ok?
There are no "local made" computer power supplies. They're all made in factories, mostly in China. Surely it has some info on the label regarding its brand or manufacturer?
In any case, with such a high 5V capacity, that sounds like an outdated PSU.
PSU calculators tend to overexaggerate. Usually not by this much though. 600-700W is about double the wattage that you actually need to get by - yes a 350W unit would also be fine (provided it has the necessary connectors and is good quality). Your parts use about 200W in typical load, 250W at most (100W for the CPU, 50W for the motherboard, 50W for the GPU and some small amount for the rest).
Yes, that's a fairly decent unit. Not the best, obviously (given it's cheap), and lacks almost all of the bells and whistles like modular cables and quiet fan, but it's reliable and backed by 5 year warranty.
thanks lehtv,well this is my calculation if it would add something here..just wanted to mention here.. Load Wattage: 331 W Recommended PSU Wattage: 381 W and cooler master recommending 600watt!
I don't see how you could get to 331W without a heavily overclocked CPU or a much more powerful graphics card. But, a decent 450W unit would still handle a 331W load just fine (though the PSU fan would be noisy)
oh that i kept 3 92mm fans,16 hours usage,x5470 cpu at 90% uitilization recommended(may be so showing 300+ watts ,and 1gb ddr5 nvidea gt 730,hmm yes there is no overclocking in the options and i too don like it much,just in case i would like to mention about my ram, all 3 rams are different ,2 rams are cas 5, one is cas 6..all three are different manufactures or company.
