Rig in sig. My system has been stable at 2530/1.475 for over a week now. Don't really need to push it farther, but that's not really the point, is it?
Started with 230 mhz. HTT, LDT/HT 4x, 166 mem. mult, and 1.475 vCore as a baseline. The memory is running at 180 mhz, so neither it or the HT bus speed are at issue; both are below spec.
Stepped up to 235 Mhz, wouldn't boot Windows at 1.475 vCore. Stepped up to 1.50 vCore and it booted Windows. Stepped up to 240 Mhz, wouldn't boot. Stepped up to 1.525 vCore and it booted to the desktop, but failed Prime95 pretty quickly with a rounding error. Dropped back to 235/1.50 and failed Prime95 again. So I am back where I started: stable at 230/1.475 vCore.
Cooling was an issue, but the processor never got hotter than 52 deg. C before failing Prime95, so it wasn't the reason for the failure. If I try it again I will need a better cooler.
So anway, I'm happy with 2530, but I think it ought to be able to go faster. I'm a little wary about going to 1.55 or higher on the vCore. What do you guys think?
