X1950 Pro Tempurature
Revolution09
520
I've been getting some flickering on my screen, like little black lines near the left side, and I figured my card might be overheating. It is currently sitting at 50 degrees, pretty much idle. Is this normal? What can I do to fix this flickering? My rig info is in my sig.
SolMiester
5,330
17
Hi, at idle my x1950pro sits at 36 degrees, what is the cooler on your?. I though asus had a good cooler also!
Schadenfroh
38,416
4
As stated in your thread in GH, my X1950 Pro idles at 53 degrees, no artifacts and is rock solid stable. Case has 120MM fans blowing air across it and out the back. I dont think your flickering is due to temperature.
Revolution09
520
If temperature isn't a problem, what else could be causing this?
