x1950 pro much better than 6800 ultra?
mricks86
335
I have a chance to upgrade my old AGP machine from the 6800 ultra it is currently using to an x1950 Pro, but I am just wondering if the x1950 Pro is enough of an increase to even bother. The 6800 ultra is 256mb version and the x1950 Pro is 512mb DDR3 version. Will there be a noticeable increase that it's worth the upgrade?
The mobo is an Abit IS7-E with a P4 3.2ghz northwood, 4gig of RAM.
Any input would be appreciated!
Thanks!
A5
4,902
1950Pro is roughly equivalent to the 7800GT if I remember. It would be better, but probably not enough to be worth spending any money on :p
rogue1979
3,062
The X1950 Pro is much faster, but you may not see it's full performance potential on a 3.2GHz P4 cpu.
k0rnh0li0
Banned
Oct 19, 2007
773
i have a x1950 pro and its a big difference.
i don't know if its just me but when it comes to converting avi to dvd. you'll see how many frames the x1950 can push out than the 6800gt. game wise a little better but 6800gt would do juss as fine.
jacktesterson
5,493
to be honest, yes, its quite a bit faster and has HDCP
it all depends on how much your spending on this though.
The 3850 is available in AGP, but Im not sure its worth going that route without upgrading to Dual or Quad, which will then be PCI-E anyways.
Click Here to see AGP
Borealis7
2,914
205
i have the 1950Pro (although PCI-e) and i just finished playing Fallout 3 @ 1600x1200 no AA on my rig. its a very nice card.
Stumps
7,125
unless you have one of CPU's coupled with an Asrock 4coredual VSTA or 775Dual board...then an AGP 3850 makes perfect sense.
Stumps
7,125
however, using a X1950 pro with a P4 is pretty much overkill, you should see some small gains but don't expect too much.
ASK THE COMMUNITY
