System Specs:
Athlon XP 2700+ with vantec aeroflow (temps are frosty, no monitoring utility installed currently though)
ASUS A7V8X motherboard
2x512 (1gb) Kingston HyperX DDR 370 RAM
Hightech X1950 pro 512 IceQ3 turbo video card
PC P&C 510 ATX-PFC SLI certified multi-rail power supply; 3.3v-30a 5V-40a 12v-34a
Sound Blaster Live Audigy 2 ZS gamer
Western Digital Raptor 74gb
4 case fans, 1 blowing directly on card. Ambient temps are frosty
My Hightech AGP x1950pro 512mb card arrived today and I immediately got down to installing it. Hardware installation went smoothly and drivers seemed to go in without a hitch. In the link above, in the specifications tab, you'll see that the clock settings are as follows:
620 core
1480 memory
On instinct, I fired up Tray Tools to check out the clock settings. They are configured, and the card's BIOS is as configured as follows:
620 core
1540 memory
Idling at 36c
Here is a screenshot. Bios settings circled in blue, current settings circled in red.
As you can see, I adjusted the core clock to its respected 620 value, as advertised, but the card arrived to me at 590. No problems at all, infact, I'm sure I can squeeze more out of it...but that's for another time. Core temp is idling at 36c.
The memory, on the other hand, is over spec and I attempted to lower it down to it's 1480 value, but everytime I touch it the damn system black-screens me and I have to reboot. I then lowered it considerably down to 1400, and it went through fine. Trying to creep it back up to 1480 has been an exercise in futility, I keep getting black-screened when at around 1440. At it's current 1540 value, the system is stable at desktop, I currently do not have any benchmarking apps and do not want to risk burning out the card.
Also note, I have had zero problems, except when I try to dial the memory clock frequency down. Would it be advisable to hack the BIOS to manually change the memory clock? I am leaning towards "no", I'm going to give this a trial run with Oblivion and I'll report back with results.
620 core
1480 memory
620 core
1540 memory
Idling at 36c
