X1900XT + X1900 Crossfire Problem
LastOutlaw
12
Well lets put it plain and simple, Every game i try works great with the 2... but Battlefield 2 on the other hand goes to a black screen then crashes. I'm trying to find out why. I asked EA and they told me it was a problem with my NIC and I said they were retards. I have the latest Cats Latest BIOS on the motherboard and i've run out of ideas. My System specs are as following
Asus A8R32-MVP Deleuxe
AMD 64 X2 3800+
2GB OCZ Dual Channel Plat
X1900 Crossfire Edition + X1900XT
FSP FX600-GLN
2X Maxtor 200GB SATA 16mb cache
I think it might have something to do with the BIOS but i don't know. I need some help here.
Ackmed
8,499
560
Same mobo, same cards, works fine for me. Latest mobo bios, and Cats. Dunno what else to say.
nitromullet
9,031
36
1) Does it work with a single card?
2) That motherboard does have 2 NICs. Try disabling the one you are using and use the other one. I used to use the Marvel Yukon NIC on my A8N-SLI Premium, and the system would sometimes crash in WoW. I switched to the NVIDIA NIC and disabled the Marvel Yukon... Problem solved. I know it sounds weird, but it worked...
LastOutlaw
12
i have 2 marvell NIC, and it works ok if i use a single card oh and i have the very latest patch
LastOutlaw
12
i updated the marvell drivers and tried BF2, i herd the EA games movie and then CTD but it was a black screen. I'll try my Dlink 530TX
Ackmed
8,499
560
I recall having the black screen problem with an older version of the game, and a GTX. I could hit the ESC key, and it went right past it. Try that maybe? As much as I like BF2, its always been very buggy.
LastOutlaw
12
ok well i put the Dlink 530TX in and it does the same thing.... BF2 just sucks in general
