- Mar 28, 2003
- 3,825
- 46
- 91
I just built the rig in my sig (well, at least the major components are new), and got myself a shiny new Antec P180 case as well.
Everything assembles easily and appears to be working fine, and then I start playing games, and I notice some problems.
Everything looks great, but while playing any graphically intense shooter, after about 5-10 minutes, I'll begin noticing the screen "flicker" every few seconds. Just a quick, split-second flash of white and distortion over part of the screen.
I downloaded the latest Catalyst drivers for the card, and still the same.
Seeing as how it does it in every game I tried (Oblivion, FEAR, Quake 4), after playing for about 5-10 minutes, I figured its probably not a driver issue of any kind. So I go and check the ATI control panel, and after exiting an intensive game session of Oblivion after a few minutes, the temperature gauge reads a whopping 100C!! In comparison, even my overclocked CPU was running in the low 40s after a load.
So I'm guessing this is "artifacting", and that its being caused by heat. Is this normal for this card? It's not o/ced at all, the case is obviously well-designed and has 4 fans. I can't figure out why it would be overheating so quickly and so easily for not being o/ced. I've been out of the ATi loop for awhile, but I seriously cannot believe a good, functioning card is supposed to run THIS hot. It's idling now at 68C, still seems pretty warm.
So would these flickers and distortions most likely be caused by an overheating card? And if so, is this normal for this card??
Thanks in advance!
Thanks in advance!
