X1900XT at 90+ C , HELP
gRaps
Ok my graphic card is running at temps above 90 C, i have no clue what is wrong, maybe i installed it wrong? does the heatsink on the graphic card need power?
Please help, i'm running the graphic card on Gigabyte DS3, E6300, corsair ddr2 800 C4 ram
yes the sink needs power but if you are using the card then it is gettin ghte power, these cards run hot and the default fan speeds may not be enough, you should DL the latest ATI tool and change the fan speeds. good luck.
90C at load I assume? I've had it get up to 95C once according to ATiTool, no idea how it happened but it hasn't got that high for a while. Can you SEE the fan moving? Did you OC the card? What drivers do you have? Information please.
Do you have proper ventilation? LOTS of cold air coming in and lots of hot air coming out of your case? Even with crossfire, my cards are 60*C under load because I have excellent air flow: 5 scythe 120mm 1600rpm fans with a fan controller.
I think one reason for the big temperature differences we're seeing between different cards could be that the stock thermal paste is not applied well at the factory. I remember someone here saying that reseating the stock heatsink and putting on AS5 or something resulted in a 10C drop. I get about 82C load at 80% fan speed even though I have two 120mm fans blowing outside air pretty much directly into the card, but I haven't gotten around to reapplying the paste yet. I need to try that soon.
I haven't heard that before, interesting. My 1900XT is idling at 50C at the moment.
ok i'm using the latest ATI drivers, i havn't overclocked anything, stock speed. at idle its about 65-70 c. When i play games it goes up to 80-90 :x
and yes the fan is moving on the heatsink, but how do u adjust the rpm of the fan with the ati drivers
you cant without something like atitool or some type of additional app that allows it, someone posted something stating it was made by ati and allows overclocking. and fanspeed ajustment
hm, the thing is i just built this computer, annndd i am experiencing sum random restarts. Not frequent but kinda annoying, just seldomly . Had about 3-4 restarts yestoday, when i built this comp
how is the ventilation in the case? what's the temp in your room? these are all variables which will affect the temp.
as someone else suggested, try adj. the fan speed higher using ati tool
What power supply are you using?
Yep, make sure you have good case ventilation.
can sum1 link me to a software that allows me to set the speed of the fan in side my video card. I searched all over ATI , coudlnt' find anything :x
I have 2 HIS XTX's & the older one with the standard cooler hits 80c under load ... the newer card is the IceQ3 & the much-improved cooler keeps it around 70c in the same conditions in a smaller case... both are clocked to the maximum overdrive settings.
install it. open it
.. you should see in your icons on your bottom right.. there should be an ATI red box.
right click it:
hardware > overclocking settings > FAN > check manual settings > crank that baby up to 50% and you temps should fall. apply and ok. your set.
I was hitting 90+ C when I put the fan at 65%, which is about all I can stand. Putting the fan at 100% cuts it to 80 C but it sounds like a vacuum.
Reapply some AS5 and test it out.
