x1800XT Screen Corruption Help???
picachux
247
First my Rig:
Asus A8N-E
Athlon64 X2 4200+ (CNPS7000B-AlCu)
2GB OCZ EL DDR PC3200 Platinum
Sapphire x1800XT 256mb
X-Fi XtremeMusic
NVIDIA nForce 10/100 NIC
WD 120GB S-ATA
WD 200GB S-ATA
Lite On DVD-Rom
BenQ DW1640
Antec SmartPower 2.0 500watt
I can play games for anywhere from 5-10 minutes before the screen goes corrupt with Black or Rainbow squares. Once I have quit the game and I am on the Desktop the corruption is gone. I have been monitoring the cards temps with RivaTuner and they are Core 621mhz/Memory 747mhz temps top out at Core 79c/Ambient 61c/Fan 45%. I have yet to see it go over 79c in all 3 games and 3DMark06. So far the corruption has only occured during Battlefield 2 Demo, Far Cry and Call of Duty 2. I ran 3DMark06 and it ran all the way through without any corruption. Any suggestions?
sisq0kidd
17,043
The only thing I can think of is your memory overheating, especially in this weather, ack! Try underclocking your memory to see if that helps.
picachux
247
Would killing the hotkey poller and running the card at Core 600mhz/Memory 700mhz be a good test?
sisq0kidd
17,043
Not exactly sure if disabling or shutting down the hotkey poller would help, but definately try lowering the memory or core speed to see if that helps. I would reccommend just doing the memory first as that would help isolate your results.
picachux
247
I killed the hotkey poller service and it ran Core 600mhz/Memory 700mhz. I played Far Cry for about 30minutes without any issues, the temps recorded by RivaTuner were about 2-3 degrees cooler. I will test it some more tommorow afternoon after I do a fresh install of windows. This install is from when I had the x800 XL and Audigy 2.
picachux
247
Today I installed a Sytrin Kuformula VF1-Plus and it dropped load temps 15c. I also noticed when I reseated the stock cooler that it offers the memory absolutely nowhere for the heat to be spread. Could that be the reason I was getting artifacts? I've been testing with Battlefield 2/3DMark05/05 all day and no problems yet. What is the max temp for the Voltage Regulators on this card?
Stock Cooler
Idle: Core 597mhz/Memory 697mhz
Core 60c/Ambient 51c
Load: Core 621mhz/Memory 747mhz
Core 81c/Ambient 61c.
Sytrin VF1-Plus
Core 49c/Ambient 44c
Core 65c/Ambient 49c.
