x1800XT power connector
Raloth
65
I'm sitting here looking at my ready-to-go system but I've got one problem. My x1800XT came with a very strange power connector. Only three of the actual 6 pins are there (you can see right through the other three holes), and the two 4-pin connectors on the other are different (one male, one female). It does not look like it's split...rather, the cables from one 4-pin go into the other 4-pin and then into the 6-pin (kind of like an IDE cable, sorry for the poor description). I'd only be able to connect one to my power supply. The power supply on the other hand has its own PCI-express connector.
Which one do I use?
i3igpete
224
it's a pass through, kind of like christmas lights. just connect one side to the supply and the other end to another item.
