- May 23, 2005
- 409
- 1
- 0
im going to be getting my x1800xt today and i wanted to know from you guys if you suggest the stock cooling since it directs the heat out of the case and the fan adjusts according to the load. or should i use my zalman v700 cu heatsink/fan which im guessing would cool better but doesnt direct air out of the case. although, i did install a exhaust fan on the empty pci slots so that might take care of that.
what do you think?
edit: another question. would it be possible to hook up the zalmans fan to the video card so the video card adjust the fan speed?
what do you think?
