thilanliyan
What's the max temperature that is safe for the voltage regulators on an X1800XL??
While testing the overclock (with higher voltage) I saw the voltage regulator temps. hit 80degrees celcius, while the core stayed under 75 degrees celcius and this is with the stock cooler.
So is this safe or should I back off. Even at stock the VRegs went to around 75 degrees celcius.
