X-Turbine problems
oSReApEr
Hey guys, I got my T-turbine case from www.xoxide.com which included 6 fans, 2 blue cathode lights and a 420 watt duel led Raidmax fan. The only problem i have is that i cant fit my duel fan psu in the case because the top fan of the case interferes with the exhaust fan... Should i remove the top fan, or the exhaust fan. OR should i just get a psu with only 1 fan, OR should i get a slimmer 80mm fan?
Thanks for your input.
blade
1957 - 2008<br>Elite Moderator Emeritus<br>Troll H
This what you have? Most power supplies that have dual fans have the second fan on the bottom. Raidmax of course is one that has that second fan on the rear. You can remove either fan, the top case fan or the one on the psu and try a thinner one. Thin 80mm fans are rare though.
I'd just remove that top fan and perhaps place it on top, or off untill you get it figured out. I wouldn't go through the trouble of getting another psu just for that reason. And a top fan isn't really necesssary.
edit-
If the psu came with the case, then xoxide should have made you aware of this problem. I'd talk to them about it and see if they'll do a psu exchange for you. Which they should and pay for shipping both ways.
chocoruacal
1,197
YOu don't need 6 case fans. Hence, ditch the top fan so the PSU will fit. That would solve your problem in the time it takes to get a screwdriver.
oSReApEr
Ya blade i have that case but in black. i guess ill just take the top fan off and place a blue cathode COunter strike grill on it :-D. Get some double sided tape ill use it to place the extra fan near the processor, or something like that.
