x-pider case front usb cable help
scoop591
Does anyone else use the Aspire X-pider case (picture here) . I screwed up and forgot the color coding for the front usb cables. I was swapping out the multiple plastic pin holders for a single holder for all of the pins. Well, I forgot to write down the corresponding color/labels and now i'm stuck. Could someone with this case tell me what the color coding is? The cables don't appear to follow any standard scheme. I have a picture of the original holders here. By the way, alcoholic beverages and case mods don't mix...
Thanks
Unfortunately, Aspire was zero help. I emailed them with no reply and their site had diagrams, but none that matched the x-pider
USB is USB, but not all color schemes match the red, white, green, and black standard. I'm trying to match the colors I have to the labels on the pictured headers. No, the headers are not Firewire.
well all I can think of is to use a volt meter to determine the ground and the 5v. What colors do you have for the two data streams then?
According to the Aspire page (perhaps you were still hung over when you went there to look), the original order of the color is black=g, yellow+d, green-d, red=5V.
.bh.
