X-FI Extreme Gamer Fatal1ty Pro Series Sound Card
Whirlwind
540
18
I was just wondering if anybody here is using this sound card, and if it is a great improvement over onboard sound?
I mainly want to use this with head phones.
If this would be a good set -up, could someone recommend me a good set of head phones to go with this card.....it will be used for gaming only.
Thanks guys.
CurseTheSky
5,401
I have it, and yes, it does give much better sound performance than the onboard card.
However, unless you really REALLY want the X-RAM (which probably makes a difference with a lower-end system, but didn't increase my framerates by much), just go with the Xtreme Music.
The X-FI cards, along with other performance sound cards, really work best if you have good speakers or headphones to match them. While I did notice a nice difference with my X-530s, I noticed an ever bigger difference between onboard and the card when I switched to my Z-5500s.
YOyoYOhowsDAjello
Moderator<br>A/V & Home Theater<br>Elite member
Aug 6, 2001
31,204
45
Yeah, get the XtremeMusic (not XtremeAudio btw) or the regular XtremeGamer and use the extra money saved to buy better headphones.
Do you know if you want open or closed headphones?
Whirlwind
540
18
I would like closed head phones.....anyone know about the razor H1 head phones.....i was thinking about those
