X-52 and X-52 Pro
MrWizzard
2,493
How hard is it to work the throttle and Stick on these two sets?
Anyone have them? Would I be ok sitting on a couch with one on my left and right, on the cushion or do you need a firm surface?
Thanks
YOyoYOhowsDAjello
Moderator<br>A/V & Home Theater<br>Elite member
Aug 6, 2001
31,205
45
Well how stiff does your joystick have to be for you to enjoy working with it?
AgaBoogaBoo
26,108
I guess you should also factor in how long each session will be, they don't all last as long as the others. We talking quick little 10-15 minute cycles or maybe an hour or two?
YOyoYOhowsDAjello
Aug 6, 2001
31,205
45
Keep in mind that we're talking two at once though. That's got to put more strain on things.
AgaBoogaBoo
26,108
We'll need to make sure they work at extreme angles because with two, the positioning is very important.
Malak
14,696
How do you work the throttle when you have your hands full like that?
