wxp networking issues
Alex
6,995
we have a small LAN here... there's 6 computers, 2x windows xp and 4x windows 98 and everything worked fine.
recently i switched 1 of the computers to xp and added another new xp machine, making 7 in the workgroup in total.
thing is, the xp machines see eachother but can't access eachother. it keeps giving access restrictions etc but i've tried everything from disabling the firewalls to enabling full file sharing etc and i just don't know what to do anymore this is getting really frustrating
i HAVE to be doing something wrong.. back home we have 4 comps, 3xp and 1win2k and everything is perfect but for some reason i can't get it to work here at the office.
some of the comps have xp in english and some in portuguese, but all are SP2 so that shouldn't matter right?
please any suggestions are really appreciated i'm desperate :( :(
note: i also get a "duplicate name exists on network" error even though i've changed the names a ton of times and they are all unique...
thriemus
215
Enable simple file sharing using tools - folder options - view tab - last option, tick it.
Alex
6,995
thanks for the suggestion but it was kind of implied in my first post that i had already tried disabling that (its enabled by default)....
anyone else?
thriemus
215
reseal the windows xp installation using sysprep then setup the computer to a different computer name, sorry about the simple file sharing. I am far from exhausted from ideas on this. :D
Alex
6,995
awesome thanks!
and thx jack for the link too!
i'll give this a try during the day today and post back with the results :)
Alex
6,995
Originally posted by: amdskip
Install netbeui too.
really?? :roll:
afaik its disabled by default and i've never had any problems without it... i guess i could give it a shot...i mean i am desperate! ;)
Alex
6,995
amdskip sorry i jumped the gun on my last post, after reading up on the linked website its apparent that enabling netbeui could definitely make a differnece! :)
Alex
6,995
Originally posted by: Micronaut
I don't recommend NetBEUI for XP - but hey, if it works - until you can find a real fix...
i've actually been tied up with other things at work today so i never got a chance to look at it, BUT on the other hand, i did set up 2 xp machines on the 'other' workgroup (there's 2 in the office) and they worked perfectly and i set them up exactly the same way as the ones that wouldn't work in the first workgroup, so i'm beginning to think the problem is with the workgroup config and not with the machines...
Micronaut
133
Uhh.. workgroup is nothing but a name for machines to associate themselves with by default. there's nothing to config. Unless you mean the 'other' workgroup is on a different subnet. And I've never seen Windows be wrong about duplicate name on network errors.
Alex
6,995
what i meant was there's 2 sides to the office, one side has a server and works fine.
the other side is connected with a router and works fine with win98 machines but not with wxp...
Wizkid
2,728
Make sure your passwords are not blank and that they are the same on all the machines. Otherwise you need to set the Local Security Policy to allow blank passwords over the network.
