WTF...my bass guitar doesn't make noise, anymore. What to do??!?
DainBramaged
23,454
41
I have a Sterling Stingray bass guitar. It decided to stop giving audio output. What should I do? Throw it in the trash? Fix it? (Spoiler: I'm not going to throw it in the trash.) ??!?
nakedfrog
63,585
20,032
Maybe there's a short in the jack itself?
Does it have active pickups?
Edit: okay, it's active, you verified the battery is connected... did you also verify the battery is still good?
DainBramaged
23,454
41
Yes, I tried the tongue test on the old 9V; it seemed good. Just to make sure, I put a NEW 9V in it. Still nothing...
Oyeve
22,075
887
You could take the pickup out and check. Or take it to a guitar store. I have rewired most of my MIJ 70s guitars and basses. Its pretty straight forward.
nakedfrog
63,585
20,032
Yep, either it's time to open it up and poke around the wiring yourself, or bring it into a shop.
Chapbass
3,147
My first guess is that the solder on the input jack severed. I've had that happen to me before. IMO, take it to a guitar tech, i bet they could fix this in under an hour.
Reactions: nakedfrog
