Wtf is this? (holes in rotor) *updated OP*
halik
25,696
They were cheaper than brembos but not bottom of the barrel, about $110/ea before shipping.
Odd, just read the thread - probably a really old batch of Centric ones. I have heard they had some QC issues initially.
I had a set of Centrics on my S4, no issues.
Vdubchaos
10,408
10
Wait, you paid $110 each for a Centric rotor?
WOW
I had centric rotors in the past, they warp easy and are not worth the DIRT CHEAP price tag that usually comes with it.
Sep 7, 2009
12,960
I believe what I said was essentially 'I have not observed any demonstrable difference.' You said you had. I said, okay; demonstrate. And I believe you then put a lampshade on your head and stood in the corner. ;P
Don't make me hit you with my cane.
:biggrin:
SithSolo1
7,740
11
WOW
These are low end Stoptech rotors. Centric is the parent company but yeah, I guess I paid $110 for a centric rotor.
DaTT
Garage Moderator
Moderator
Feb 13, 2003
13,295
121
Glad it is getting resolved at no cost to you.
Jimzz
4,399
190
WOW
Centric has several levels of rotors.
Rotors don't "warp" by themselves most of the time its the driver and/or the car setup that cause most.
