wtf does low level formatting do?
I *think* a low-level format turns all the bits on a storage device to "0" so there is no way of recovering any kind of data, wehre as most formatting just erases the pointer to where the bits that corrispond to a peice of data are.
I could be wrong of course.
Think of a tree in the woods... you cut it down, and it's a log on the ground. Can you use it like paper yet? Nope... it has to go to the factory, be ground up to a pulp and pressed into something that you can use.
Tree in the woods = HD from the factory, low level format = taking the raw materials and making it so the computer can write on it.
Right, except it's not IMPOSSIBLE to recover the data.
That's a terrible analogy😛
WTF that analogy doesn't even make sense... well it does but not for hard drives/storage.
Low level format writes 0s, and it is still very possible to recover data. A 0 that has been a 0 is different from a 0 that has been a 1 for a long time and is different from a 0 that was changed to a 1 for a short period of time and then back..
Originally posted by: Heen05
so how often should i low level format? 🙁
Never, flash cards have a certain life cycle for complete zero writes of the bits, its something like 1000 times for an sdcard I think.
If you are selling the card and it had some private data at some point, do a low level format 2-4 times to make sure the data isnt recoverable.
On my camera in the menu there is an option that says something like "erase memory stick." Is that actually idiot speak for a low level format? I figured it was just deleting the file addresses.
no.
no. do a DoD erase ONCE.
I thought it was a pretty good analogy
I would use this analogy:
LLF to Storage is what Bruce was to Bruce Almighty without the happy ending.
Being able to make women orgasm on demand?
I don't need the command line for that😉
*waits for clever wordplay*
