WTF? Audigy2 ZS has no connectors for front panel inputs?
The Sauce
4,741
34
This "top of the line" sound card has no connectors for front inputs - which are standard on most cases today? Now how am I going to use my headphone/mic for UT2004? Which, coincidentally, is what I bought the bloody card for in the first place? Is there a workaround for this that anyone knows of?
Nebor
29,582
12
The cards have connectors for front inputs, just not case inputs. Buy a live drive breakout box thing that goes in a 5.25" bay.
JackBurton
15,993
14
The Audigy 2 ZS have front input jacks, it's called the Platinum and Platinum Pro. ;)
The Sauce
4,741
34
Lot of good that does me. This blows.
Nebor
29,582
12
REturn yours and buy a Platinum or Platinum Pro.
The Sauce
4,741
34
$90 was a lot to spend on a card for it not to have a basic, standard feature. That's like buying a motherboard without an IDE connector. I'm not going to shell out another $60 to get it to do something it already should. I'll find a way to deal. I am again reminded why I have always hated Creative...they leave out a basic fecture in order to get you to buy the next more expensive product.
Imdmn04
2,566
Well you didnt buy the top of the line, if they gave u this feature, who the hell is gonna buy that platinum line?
RainofTerra
52
Did anyone get this working? I've tried but can't seem to get it to work.
I really like this card and I really like this case, the fact they don't work together bugs me. I don't want or need a live drive, I just want the front output connectors to work.
Any ideas?
-Jeff
Nebor
29,582
12
Connect them to your mobo and just go through the hassle of switching your output device when you want to use the front panel for sound. :p
I just plug my headphones into the jack on my Creative Gigaworks. As long as you give Creative lots of money, you'll be happy.
pukemon
850
hrmmm my creative T5400's have a headphone jack on the volume control/wired remote... so i guess that's one solution...
dlerious
2,065
874
Interesting. I have a Live 5.1 Platinum with the Live Drive IR. I wonder if the Live Drive
will work with the Audigy2?
EeyoreX
2,864
This is neither "basic" nor "standard". Just because many more cases have the connectors, that in no way makes it a standard or basic feature. It will be standard when the connectors on all these front connectors use the same connection and there is a published standard that we can view and read. You want this feature as a "standard"? Buy the more expensive card that has this feature "standard". Just like early on when I wanted this feature "standard" on my case I had to pay more for a case that had the connectors.
\Dan
acemcmac
13,712
I ran into this same issue. If you talk to creative, they'll act like you're a space alien. SPDIF connectors are accessable, but apparantly the breakout connection for the live drive is all digital so it's impossible to leach off the analog channels. It was possible before with the audigy 1. All audigy 1 port maps are public. Audigy 1 and 2 breakouts are different pinouts and are not interchangeable.
I already have 5 drives and a newq platinum, I refuse a breakout box for just a headphone jack. FU creative.
If you patch it back through your mobo, you lose the >104 clean signal and add in the mobo's line noise, making your card an expensive SBL. I don't reccomend that. I had to make my newq an eye candy dead-end box (except FM patch recycler) for the same reason.
The best plan IMHO (and the way I went) was to get a set of THX speakers to compliment the card with a headphone jack in them. I haven't heard a bit of white noise ever since.
and again, live drive is a giant POS for just a headphone jack. The digital pinouts are an even bigger scam... grrrr....
as far as your mike goes.... just get a boom mike and upgrade to headphones that will be able to reflect the quality of the card. My setup is the card, Z5300's and Sony MDR-700's :beer:
Pugchucker
139
\Dan
There is a documented Intel standard for front audio connector inputs and it is used on virtually every single motherboard made today with integrated sound. If it being used on every low-end integrated mobo sound system does not make it basic and standard then I don't know what does.
acemcmac
13,712
\Dan
I've never seen it on a sound card tho... Anyone have pics of a descent sound card with these headers?
